#9781 artho
Napisano 03 luty 2021 - 22:34
Tutaj więcej: https://forums.garmi...me-elapsed-time
#9782 Blackthrone
Blackthrone
  • 35 postów
Napisano 03 luty 2021 - 22:48
Dzięki.Poczytałem i już chyba wiadomo jak to jest wyliczane ale według mnie to jest skopane i nie do końca to pasuje tym bardziej że zauważyłem ze średnie prędkość  też nie pasują bo nie ma średniej prędkość  z upłynęło czasu .pozdrawiam
#9783 Prozor
Napisano 05 luty 2021 - 12:16
Aktualizacje fenixów 6: przeskok z bety 14.72 na betę 15.01:
fenix 6X Pro Ver. 15.01 Beta - 02/03/2021
Adds tone and vibrate to ClimbPro climb approaching alert.
Fixed an issue where 'Course Complete' may be shown incorrectly.
Fixed an issue with the units shown in PacePro split alerts.
Fixed an issue where payment cards without images were unable to be used with Garmin Pay.
Fixed an issue where sensor software update prompts were being displayed incorrectly.
Fixed a crash that could occur after the sensor software update prompt, when a CIQ watch face was also active.
(This version can be downloaded from: Garmin Support Download Section)
Dla F5 nieco mniej poprawek:
fenix 5X Plus Ver. 14.72 Beta - 02/04/2021   Fixed an issue where screenshots generated from device did not look right.
Fixed an intermittent issue with Livetrack.
Fixed an intermittent issue where the device may freeze while using Garmin Pay.
Co ciekawe, dla FR945 aktualna beta wygląda tak:
Forerunner 945 Ver. 6.04 Beta - 01/21/2021   Improve the software update process for external accessories. Installation prompts will now appear after an activity to avoid interrupting activity start.
Improvements to heart rate broadcast.
Add more smartphone app logos for smart notifications.
Block music controls and disconnect headphones in airplane mode.
Fix a rare issue that could cause heart rate data to appear flat in Garmin Connect.
Fix an issue that could prevent LiveTrack from starting when Auto Start is enabled.
Fix a graphical issue with workout alerts when the background color is set to black.
Fix an issue sometimes causing distance remaining to not display the hundredths digit.
Added alerts for ClimbPro to notify of upcoming climbs.
Added descents to ClimbPro when enabled for non-cycling activities.
Other minor improvements and bug fixes.
Pogrubiłem najciekawszą część, pierwsza wprowadzona w F6, druga, czyli ClimbPro dla nachyleń ujemnych w przypadku aktywności innych niż kolarstwo jeszcze nie została w F6 wprowadzona (tylko w FR 945 i 745). Swoją drogą pewnie sporo ludzi chętnie widzieliby tą funkcję również w kolarstwie górskim, może nie tak użyteczna jak przy podjeździe, ale na zjazdach człowiek wiedziałby czego oczekiwać...
#9784 FigoiFago
FigoiFago
  • 138 postów
Napisano 05 luty 2021 - 21:43
Dzisiaj pojawił sie u mnie do pobrania soft w wresji 7.1 dla E530
#9785 Prozor
Napisano 05 luty 2021 - 22:18
Tak, dla całej serii x30. Tyle tylko, że nastąpiła tylko jedna zmiana:
Fixed issue preventing Wi-Fi certificates from being acquired.
Tyle tylko, że postęp w przepychaniu aktualizacji jest jak zwykle ograniczony. Do mojego E1030 było to jakieś 20% i oczywiście musiałem ręcznie wrzucać do Edge, albo cierpliwie czekać na oficjalne źródło akualizacji...
#9786 czarusblitz
czarusblitz
  • 644 postów
Napisano 07 luty 2021 - 12:48
Witam, gdzie można znaleźć w ustawieniach licznika serii x30 test rampowy FTP wg protokołu Firstbeat? Nigdzie nie mogę tego znaleźć...
PS: już znalazłem. Jedynie pytanie, czy ręcznie jest już możliwość zmiany wartości FTP do celów testu?
Using Tapatalk
#9787 Prozor
Napisano 07 luty 2021 - 14:36
Z tego co widać po komentarzach:
Niestety u mnie w830, po zmianach przez Connect , zmienił się tylko poziom ftp. Strefy testu ftp bez zmian.
I wcześniejszych, to chyba nie. Przynajmniej nie od razu i od ręki. Może Connect potrzebuje czasu do przetworzenia danych i wysłania nowych parametrów testu, może jednak po wykryciu nowego FTP ustawia z automatu na tą wartość i utrzymuje do wyznaczenia kolejnego poziomu, bez możliwości wpisania z palca. Sprawdź.
  • czarusblitz lubi to
#9788 artho
Napisano 07 luty 2021 - 14:41
Chyba aktualizował po wykonaniu pojedynczej aktywności z tym nowo wpisanym FTP.
#9789 Prozor
Napisano 07 luty 2021 - 15:22
Być może, trzeba byłoby sprawdzić i zweryfikować. Na pewno nie aktualizuje po wpisaniu tuż przed zrobieniem testu.
#9790 HarveyDent
HarveyDent
  • 1105 postów
  • Skądwe mnie tyle piękna
Napisano 07 luty 2021 - 16:00
Z ciekawostek: robiłem kontrolnie klasyczny Ramp test na Zwift żeby sprawdzić czy dalej w moim przypadku zawyża i o dziwo Garmin sam wykrył nowe FTP. Wcześniej to się nie zdarzało i ewentualnie wykrywał tylko z 20 min wysiłków. A teraz najlepsze : Garmin nie przeszacował i zaproponował nowe FTP na realnym, niższym poziomie niż zasugerował Zwift. Ramp test "dodaje" mi 10-15W tak że mile zaskoczenie.
To jest Forum Fanatyków
marvelo
#9791 Prozor
Napisano 07 luty 2021 - 17:19
Potwierdzam, jak chyba w grudniu jeszcze robiłem Ramp zwiftowy, to miałem podobnie, również FTP z Ramp Zwift ocenił jak dla mnie zbyt optymistycznie, na pewno godziny na takiej mocy bym nie pociągnął (ze 40 minut pewno...), wolę oszacowanie na bezpieczniejszym poziomie, stąd wydaje mi się, że test garminowski jest w miarę obiektywny, a na dodatek dość łatwy do przejścia i w związku z tym może być często powtarzany, nawet jako element treningu np. po każdym wypoczynkowym tygodniu.
#9792 d.m.
d.m.
  • 177 postów
Napisano 07 luty 2021 - 20:16
Dzisiaj robiłem Ramp Test w TrainerRoad i Garmin 830 wykrył nowe FTP pokrywające się co do wata z tym co wyliczył TrainerRoad (czyli 75% z najmocniejszej minuty).
#9793 Prozor
Napisano 08 luty 2021 - 23:06
Autor pola IQ "Moc docelowa" - TarPow (Target Power), udostępnił kolejne pole:
NextTarPow - czyli następna moc docelowa, moc docelowa następnego interwału. Myślę, że jest to dość przydatne, bo można co prawda sprawdzać na rozwijanej liście co będzie następnym krokiem w treningu, ale jest to mało wygodne. A tak mamy dodatkowe pole na ekranie treningowym i wiemy czego się spodziewać...
Do pobrania: https://apps.garmin....9a-d6e40e24cb66
  • artho i samuraj_84 lubią to
#9794 sirkozi
Napisano 14 luty 2021 - 11:05
Też robiłem test garminowy, chciałem nawet pochwalić za przyjazny UI, ale ostatecznie mam mętlik. Garmin przerwał mi test po skończonym 4 kroku. 5 krok dałbym jeszcze radę jechać, pewnie nie cały, ale z 1-2 min na pewno. Zupełnie nie rozumiem jak to ma działać, myślałem że to jest test do odcięcia? FTP wyszło wg mnie trochę zaniżone.
#9795 artho
Napisano 14 luty 2021 - 11:08
Nie jest do odcięcia, bo to nie jest stricte test rampowy. Garmin wykrył moment, kiedy Twoje HRV po prostu leci w kosmos i to mu wystarczyło. A to, że Ty byś się jeszcze chętnie anaerobowo styrał chwilę dla wyniku jest na nic :P.
Przynajmniej ja to tak rozumiem.
#9796 sirkozi
Napisano 14 luty 2021 - 11:25
Ok, przypuszczałem właśnie, że to może mieć związek z tętnem. Co jeśli nie miałbym podpiętego czujnika? Nie da się zrobić testu?
#9797 Born Ready
Napisano 14 luty 2021 - 11:27
Warto zmieniać E520 na E530?
#9798 artho
Napisano 14 luty 2021 - 11:51
Wydaje mi się, że test się nie uruchomi, tutaj napisali tak jakby był on wymagany:
https://www8.garmin....C563477E6D.html
Ja bym wziął od razu E830. Wiem, że drożej, ale pomyśl tak: nie kupujesz tego sprzętu na rok, posłuży pewnie 3 lata kompletnie bezproblemowo, te 3 może 4 stówki warto dopłacić. Ja początkowo wziąłem E530 a następnie "zamieniłem go" na E830 dla ficzerów nawigacyjnych.
  • sirkozi i Born Ready lubią to
#9799 HarveyDent
HarveyDent
  • 1105 postów
Napisano 14 luty 2021 - 12:06
Dla szybkości, nawigacji, lepszej baterii, climb pro warto.
Dla łatwiejszej obsługi nawigacji warto do 830.Choć jak bym potrzebował jakoś szczególnie to rozważał bym większy ekran (1030).
  • Born Ready lubi to
marvelo
#9800 przech_mistrz
przech_mistrz
  • 120 postów
Napisano 14 luty 2021 - 12:18
Tu chyba niezła cena za 1030 - 1667 zł + 17 zł w punktach na następny zakup - https://www.bikeinn....hed/137993814/p
Refurbished, ale w przypadku Garmina to chyba nie problem.
