Canyon Ultimate SLX
  • Please log in to reply
93 replies to this topic
#21 1415chris
  • 4,485 posts
Posted 14 July 2011 - 22:46
Components:
Bar caps Cinelli 5.5
Bar Tape Cinelli cork 30.3
BB Campagnolo SR 43.6
Brakes (Front) KCNC C7 85.3
Brakes (Rear) KCNC C7 82.6
Cables Brake Niro/Power Cordz 60.7
Cables Derlr Niro/Power Cordz 32.8
Cassette Sram 1090 11-25 162.6
Chain KMC X10SL 105+1 233
Crank Campagnolo Record 11s 643.4
Derlr (Front) Sram Red 68.8
Derlr (Rear) Sram Red AFC pulleys & pivot bolt 125.6
Fork Canyon 114 SLX 344.5
Frame Canyon Ultimate CF SLX with bearings 1057.2
Handlebar Token TK9735 44cm 189.1
Hanger Canyon 8.8
Headset Syncros w/o bearings 32
Pedals XPEDO Thrust 195g 188.1
Seat Smud-Carbon 66.5
Seatpost Ritchey WCS/VCLS 27.2x300 142.9
Seatpost clamp Canyon 16.6
Shifters Sram Red 294.9
Skewers J&L Titanium 27.2
Spacers Canyon 10mm 8.8
Stem Ritchey WCS 120mm Ti bolts 130.2
Tyre (Front) Veloflex Extreme 228.8
Tyre (Rear) Veloflex Extreme 238.7
Wheel (Front):
rim Carbon 49mm 302.5
hub BikeHubStore 67
spokes Mack 424 90.7
nipples Sapim Polyax 14mm 6.7
valve extention Planet X 5
washers 1.4
Wheel (Rear):
rim Carbon 49mm 309
hub BikeHubStore 212.1
spokes Mack 424 112.2
nipples Sapim Polyax 14mm 8.1
washers 1.6
Totala 5669.8g
#22 1415chris
  • 4,485 posts
Posted 24 July 2011 - 12:43
Kolka maja za soba pierwsze km. Troche sie obawialem, jak sie zachowaja, zostaly dociazone na ok 110kg.
Odbylo sie bez ocierania o klocki, nawet stajac w korbie nic sie nie dzialo, proste, bez zadnego bicia. Kola sa sztywne, nawet z takim obciazeniem!
Niemniej dla finalnych ocen zaczekam az beda mialy za soba pare tys km.
Polecam szprychy macki 424 jako bardzo dobra alternatywe dla sapimy cx ray, maja niemalze identyczna wage, sa 50% tansze i wyglada, ze mozna na nich zbudowac lekkie sztywne kolka.
#23 1415chris
  • 4,485 posts
Posted 06 August 2011 - 16:25
Czesci na wade:
http://imageshack.us...0723150747.jpg/
#24 Kuba
Kuba
  • 70 posts
Posted 07 August 2011 - 06:08
Z pelnym 0.5l zero jakichkolwiek problemow. Bede kupowal do nich 750ml ale nie widze powodow zeby nie daly rady.
A jakie planujesz te 0,7l? Kupiłem tune i niestety płytko wchodzi.
#25 1415chris
  • 4,485 posts
Posted 07 August 2011 - 10:10
Tune to Tacx-owy Source, skoro mowisz, ze plytko wchodzi, to sprobuje Shiva, poza tym wole jednak zakrecane korki.
#26 1415chris
  • 4,485 posts
Posted 21 August 2011 - 22:45
Troche zdjec:
http://img11.imagesh...3962097x4e.smil
#27 1415chris
  • 4,485 posts
Posted 19 September 2011 - 18:31
Zdjecia w lepszej jakosci.
http://imageshack.us.../dsc0689tj.jpg/
#28 Gosc_kluseczka85_*
Gosc_kluseczka85_*
Posted 19 September 2011 - 19:04
Chris, jak gdzie składałeś koła?? Ile za to wszystko wyszło>?
#29 Gosc_kluseczka85_*
Gosc_kluseczka85_*
Posted 19 September 2011 - 19:05
pytanie dotyczy tylko kółek>:) :-)
#30 dajcie mi góry
dajcie mi góry
  • 129 posts
  • SkądKatowice
Posted 19 September 2011 - 19:35
było, poszukaj, nie spamuj
#31 gibber
gibber
  • 1,204 posts
  • SkądN. Tomyśl
Posted 19 September 2011 - 19:52
To jest piękne!
#32 Gosc_kluseczka85_*
Gosc_kluseczka85_*
Posted 19 September 2011 - 20:03
Nie do ciebie było pytanie kierowane,więc wyluzuj.
Nie pamiętam by Chris mówił ile go koła wyniosły i skąd to wszystko ściągał.
To że Chińczyk to wiem... ale potrzebne mi są szczegóły
#33 1415chris
  • 4,485 posts
Posted 19 September 2011 - 20:36
TU znajdziesz wszystkie informacje.
#34 Gosc_kluseczka85_*
Gosc_kluseczka85_*
Posted 20 September 2011 - 20:03
Dzięki
#35 1415chris
  • 4,485 posts
Posted 16 November 2011 - 19:43
Rower, a raczej tylne kolo dostanie kasete:
Sram 1090 przechodzi do nowych kol codziennego uzytku.
Po tej zmianie waga roweru 5594g.
W drodze jest lancuch yaban, niestety nie z serii 210 (jakos ciezko znalezc mi usprawiedliwienie dla takiego wydatku), bedzie to 101 ti.
Chcialem porownac go do kmc 10sl ti, ktory to obecnie mam w 3 rowerach i jestem z niego mega zadowolony.
Poza tym koledzy z Tajwanu przeslali mi calkiem fajne piasty 262g zestaw. Problem w tym, ze nie z taka iloscia dziurek jaka chcialem.
Takze najprawdopodobniej beda na sprzedaz (20/24).
#36 wojtekmtb
wojtekmtb
  • 367 posts
  • Skądmazury
Posted 16 November 2011 - 20:44
A w jakim kolorze masz te piasty ?
#37 Gosc_Grzegoez30_*
Gosc_Grzegoez30_*
Posted 16 November 2011 - 20:47
Moje marzenie jest w trakcie realizacij to Specialized S-WORKS TARMAC SL3 SRAM X2 ;-)
#38 Gosc_Grzegoez30_*
Gosc_Grzegoez30_*
Posted 16 November 2011 - 20:51
jak tylko będzie dostarczony to foty będą :-) Pozdro
#39 1415chris
  • 4,485 posts
Posted 16 November 2011 - 21:37
wojtekmtb w jedynym slusznym... czarne
Grzegoez30
cieszymy sie Twoim szczesciem, tylko oswiec mnie, czemu to moj wlasnie temat zostal obdarzony takim zaszczytem......?
#40 Gosc_Grzegoez30_*
Gosc_Grzegoez30_*
Posted 16 November 2011 - 21:39
Tak po-prostu spontan ;-)
